Voice commands dont work with GTV-BT1 on Formuler Z11 Pro Max
  • I am unable to get the voice commands to work using the GTV-BT1 remote. The Formuler firmware version is current.
    Please help.
    Have you already programmed IR remote to your TV via "Setup TV IR Control" in the Formuler Remote App?
    Are you to initialize the microphone via clicking the Google Voice button on the remote? Or by selecting the microphone on the onscreen keyboard when initializing a search?
    What Voice command are were you trying to execute?
    How long have your box and remote been activated? Are these brand new?
    Please help.
    Be sure the Google Assistant is enabled by toggling ON.
    Formuler Home Screen > Settings > Device Preferences > Google Assistant
    Once you do that it will take you through a short setup.
    You can then select the apps to communicate with.
