how to update EPG without manually doing it
How to update EPG without manually doing it
- Z11 Pro MAX
- MYTVOnline3
TD358 -
January 18, 2025 at 2:19 PM
What connection are you on (xc/mac/m3u) ?
EC
What is EC?
OK,what you can try out is shortening epg update interval.
MOL3 menu>Content Manager>Content Sources>show hidden info>edit>epg update interval:set it to 3 hours.save/update
MOL3 menu>Content Manager>Data sync>Auto Update Settings>Scroll down to " EPG data storage " and shorten to 3 days to see if that helps ??
Good suggestion,however i doubt if on XC connection you will have 3 days epg storage,in most cases?
So far I did what Henkie said to do and it has been working great automatically changing.
Hey, a lot of the EPG data is wrong! Unfortunately, this is the case with all providers; it's never 100% accurate!
Why can't you manually assign the ID, etc., like with Sparkle TV and many other players?
I do have the Xeev Editor, but it would be better without Xeev in the future!
It's a shame, because otherwise, MyTVOnline3 is the best app.
Go to mytvonline3, Contentmanager, select your subscription, edit and choose "epg interval" and set it on 3 hours.
Then go to "epg offset" and play with -2 hours or + 2 hours or so. And then select on bottom "update".
and check your epg if its good or not.
Go to a channel where you now the name of the programs playing.
Then have a look at the epg how many hours it's wrong. Then try it in the "epg offset" to set it good with the hours.
