I have now multiple IPTV providers.
One is not active.
How do I delete a provider so all channels for the provider also disappear.?
Does it do that when I remove the IPTV provider too?
Remove IPTV provider.
- Z11 Pro MAX
- hints & tips
Akita -
March 20, 2025 at 8:11 AM
hi
In the menu->content manager->content sources you can: 1) disable a provider (all channels, vods and series will disappear) or: 2) delete a provider (of course here also all channels, vods and series will ge gone).
hi
Thanks!
Then I just need to select option 1 if I want to activate again. -
How do I deactivate.
Both are selected but I can't uncheck one in the picture on the left.. -
hi
I can't check right now, but if you are on a provider, on the top middle-right there are some options, one should be 'deactivate' or something.
Both are selected but I can't uncheck one in the picture on the left..Choose the disable icon on top row 4th along if you want to delete the provider altogether choose the bin icon
2 choices.
If your account expired and you dont want to renew it...
...delete it then.
All done then
