Posts by Lucky13
    So when you say vod you see image but no sound?
    And in first message you got both not? No image, no sound.
    Z11 can play h264, h265, vp9 or so. Don't know the name of codec on moment. But at my side, i got 4 portals. All play fine.
    Close mytvonline3.
    Go to android settings.
    Set Sound settings from automatic to "use no surround".
    Restart box.
    Start mol3 and test again. Its now no surround. So if you got sound now it's a problem yes with the surround.
    Test that first please.
    So after vod test and you got sound with mol3.
    Close mol3, and go to androidsettings and change sound settings from "use no surround" to automatic.
    Restart box.
    Open mol3 and play movie, if you here again no sound.
    Sent log files: how to send log files
    Btw: play the sound via tv or soundbar/sound system?
    SAM, thank you.
    It's not a provider issue as it was working with all three and then the box updated and the Ethernet stopped working so definitely something to do with the update has caused it if it's not sorted before the end of January it's getting returned and will continue using my shield
    Wait for the upcoming updates and you will have the best box ever! Have patience please.
    PA1NT and everyone who needs SMARTTUBE.
    Remove first smarttube from your box.
    Download the new stable smarttube. Put it on usb or so.
    https://github.com/yuliskov/SmartTube/releases/download/latest/smarttube_stable.apk
    In google playstore search for
    "fx file explorer" or "x-plore" app.
    Download that app and via that app install the smarttube app!!
    So start first "fx file explorer" app.
    And via that app you can open usb and or where you have downloaded smarttube.apk
    Install it via fx file explorer app or X-plore app.
    (If you install it direct from usb and or the normal way it will install, but no app logo appears!
    (That's the reason you need to install it via one of those 2 apps.)
    Summary:
    If you use the normal installer from google the app icon won't appear.
    Install it via fx file explorer and or x-plore App.
    I did it myself and a forum friend also that way, and it worked out for us.
    The ethernet connects Sam but doesn't allow a connection to MOL3 but works perfectly fine in WiFi I hope it gets fixed soon as really liking the box except this problem
    Is your iptv subscription set to vpn at the provider?
    Contact them and let your sub set to a vpn connection.
    You can connect with wifi, but not with ethernet. Only with ethernet and vpn.
    Try with ethernet later as provider set your subscription to vpn connection.
    Hi all I have the v12 ultra that has I issue as soon as plug in to ethernet the MOL3 doesn't work at all but works perfectly fine on WiFi any ideas what the issue is? Have tried a factory reset and the box wouldn't update via ethernet either.
    A know problem will be fixed in next update i think.
    Some has also that wifi won't work?
    Do you use a vpn? If yes, which one.
    If ethernet is plugged in, disable ipv6 and setup a static ip.
    If you don't know how ask on forum.
    Maby it helps.
    Ok I received the Samsung t7, 2TB. With 10euro discount.
    I formatted it to NTFS. For some reason exFat wasn't recognized by the formuler. But NTFS is also good.
    Ntfs with 64kb clustersize. Thera are coming big files up.
    If you format other clustersize, also fine.
    I've got several GTV's and I noticed that recently the Smarttube app on all boxes was uninstalled.
    Reinstalled it with Downloader but I think it's odd. Is it due to a (silent) Android update?
    Furthermore, all the GTV's show incidentally hick ups/buffering on several apps (i.e. NLZiet). On other devices (Apple TV, tablet) no hick ups.
    Smarttube is still on my z11 and z12 this afternoon. So far i know is that it won't update anymore cause there is a problem with the signature. Others use the signature from Smarttube. They maker of it is beware of the problem and bring those days a new update out.
    Can be installed over the old one he said.
    I think he bring it out on github.
    I can post link Here when new version is arrived.
    About the hickups...
    Came it after you install a new app or so?
    Do you use vpn?
    I hope you use ethernet cable and no wifi?
    Ipv6 is off?
    At internet settings at private dns. Try dns quad9 and or cloudfare.
    Then push fast on remote twice on home (house) button. You see all open apps. Push then red button to close them all.
    Restart box due hold onn/off button for 2 seconds and choose Restart/reboot.
    Possibilities:
    Is possible that the assigned VPN IP mirrors your local IP space and is conflicting ? Usually VPNs are in the 10.x.x.x range whereas home networks ahve 192.168.x.x private space.
    Is VPN is configured for split-tunneling ? Formuler box sees two different paths for the same network address range. It gets confused about whether to send the traffic through the local router (to reach the NAS) or through the encrypted VPN tunnel.
    bonggo
    You must choose with a vpn always fastest server or gome country if bo restrictions there.
    VPNs have much ip addresses. Not 10.x.x.x and 192.168.x.x that are local network addreses.
    I think you need connect first to an country. Mostly you see then an ip address other that your home router has normal.
    Nas is local network right?
    So splittunneling it. Faster network speeds.
    I did updated firmware and i still have problem with IPTV provider 1 day work ok and interm stop working (But when i use STB emulator its ok)?
    I am sure its my box or speed internet. Should i get a VPN.?
    It's not 100% stable yet, updates are coming soon. It will be better.
    Stb emulator is mac id.
    Ask to convert your subscription from macid to xtream codes api.
    Url, username and password.
    Much safer and functions like catchup and vod are better.
    I guess this might be biased. I'm thinking to upgrade my box i am pretty satisfied with mine is it really worth the upgrade?
    Yes my friend,
    Z11 has the AndroidTV playstore, dolby armoa, dts, dts-hd etc, and every app you download works on your box.
    Also faster, better etc.
    Or you go for the Z12. Also the AndroidTV playstore, so all app work on the box and has dolby atmos and dolby vision. I hope your tv has is too.
    Go for the Z12, yes a lot of money and need some updates but is the best device yet. you can go forward for years. Z11 was on launch also not perfect, but that one got some updates from time to time and it’s perfect.
    I advice Z12 if your tv/surround set has dolby atmos, dts, dts-hs, thruehd and your tv has dolby vision.
    Mytvonline3 works great. But there ar updates on the way who make the box better and better. But give the developers some time.
    Cars, tv's and computers get also updates.
    Z12 it's is mate. And also bluetooth remote. So your box can you hide a little bit.
    Goodday my friend.
    Suddenly only black screen. I can connect with my provider and i can refresh but when starting tv or vod a black screen
    Does enyone recognize this problem and knows how to solve it
    Now i did reset to factory settings to solve it but that is not my first choice
    Black screen can happens if the source of your iptv provider is (temporary) out. Try it later again.
    And or if you have installed on 2 boxes your subscription, and the other one is ON, it can happen too.
    1 device at the same time. (Or you have a double sub)
    If i can help you with more questions, apps, etc. ask me.
    Good to know, when i click twice home button there where 10 apps open in background close them all now its faster. I think the ram data was full there.
    Did you know if there is a free app for closing apps? I know memory cleaner from the market but this only clear the cache of everything. Maybe Formuler can make a auto background killer app for in the market?😅
    I have "killallapps amoled" on my nas.
    Must install it and test it. Think it's a mobile version. But like i said, i need to test it one time.
    Mol3 restarts when i use stremio and watch a movie. Gpu overload i think. But no big deal most of the time i use it on my laptop works always much faster because more ram and cpu.
    Mol 3 on a a channel with 50pfs and dolby digital plus.
    Push on house button on remote and start stremio. Watched 5 minutes the movie "speed 2' as example.
    Closed stremio and mol3 was still running?
    Maby it need to watch longer.
    I have developers function on the box ON, so the cpu catch it's full speed.
    No problems yet.
    When i use the Stremio app, Mtol3 closes and restart. When i turn off Hardware accelration it works fine. I think the gpu buffer is full. Does more people got this with stremio and is it dangerous or normal reaction from the box hardware?
    I have stremio, but should check.
    Is hardware acceleration an option in stremio?
    Then is start mol3 and stremio. And how do you see mol3 is closing? When you close stremio and mol3 isn't in memory again or? (Push 2 times fast on house button)
    Do you mean that?
    Same here with Z11 Pro and NordVPN.
    Caused due vpn.
    Box makes connection with nas.
    Box makes vpn connection.
    Disconnecting due connection to vpn.
    But doesn't reconnect to nas.
    Manual fix is to reconnect it yourself.
    Formuler can make a fix like: connect to NAS after 30 seconds or after booting. Within the 30 seconds the vpn is already connected, after 30 seconds that the box connects to nas.
    Just a delay for nas connection.
    The one I have upstairs had no problem, only the new one downstairs. Same installations on both 2. Yes I run express vpn and also ethernet on both. This morning I did a factory reset and it seems to be working fine so far. Will keep an eye on it in the future. We mostly check upstairs.
    https://www.dropbox.com/scl/fi/ibhu89b…aip0bke7gn&dl=0
    Reg
    svejoh
    Remove audio optimizer. Isn't nessesary on Z12.
    Disable ipv6 on bottom at ethernet settings.
    Rest i think about yet.
    Try first static ip to setup with ethernet.
    And router already restarted?
    I can help with static ip if you don't know how.
    Video's you can upload on streamable.com. make an account and upload and place link.
    But it's i known problem i read somewhere. With wifi and with ethernet. Some devices has that bug.
    I don't. I use ethernet cable and vpn and works??
    So not everyone is affected, but the devs are known with the problem.
    Do you use vpn? Tr static ip if you know how to and reboot router also first.
    Bundled is different apk's arm7, arm8 and or androidtv version bundled. All in one.
    Apkm or apks are bundled apk's. Therefore you need special installers like apkmirror installer, file manager plus and or other apks/apkm installers.
    Something like with Windows.
    .exe files and .msi files. Does the same, both install software files.
    You double post my friend.
    Don't do that please.
    I haven’t found any working netflix so far. Impossible.
    Some say the market version works with mouse and keyboard Only. But i have tried that but i can't login. And yes, the credentials are okay. 100%. This week or weekend i saw a forum user who has found a working netfkix version. But he never answered again so i think it's not working. People search for years for working netflix, but use netflix on your tv. my tv have netflix and has dolby vision, 4k, and dolby atmos. So always better on your tv then on your box.
    Netflix from Market or Google Play dont work.
    Will a Netflix APK work, sideoaded?
    Any particular version? I found several...
    Impossible.
    Some say the market version works with mouse and keyboard.
    Hello I have a Z8 which has been in use for the past 5 yrs with no issues,with same provider,been a great box.However now whenever I try to launch The MYO2 it tries to start but then the power light goes out on the box and it kicks me back to the main menu every time.Sometimes it will say Formulerservice stopped close app.Every other app I have installed which is just youtube and the apps which came with box work fine. I have reinstalled the app a number of times,have done a factory reset a number of times,did a backup and restore,rest data reset software all to no avail.Is it time for a new box? :frowning_face:your input is appreciated thanks
    Goodday my friend,
    You say power light goes out. Can be that the adapter is bad.
    You can try a other adapter with the same specifications.
    Maby you can order in your country a z8 power adapter and test it. If it works keep it and if it's not helping sent it back.
    You have younbox already factory reset done. And still not over the problem. So try another adapter and if that doesn't help. Go for a new box i think.
    Samsung t7 is a good one.
    Again recording error.
    Setup recording via guide this afternoon at 18.00 hours for program. (In mol3 is timeshift activated and at dvr options is the usb (ntfs formatted) selected.)
    I diner at 17.30 and box was ON.
    I come back from diner and again with z12 recording error.
    Pushed manual recording and it records.
    Sometimes it works and sometimes it won't.
    Reformatted usb when i got z12.
    I don’t agree with afoldal because on Z11 Pro Max when starting a VOD with DD 5.1+ soundtrack (eg. Yellowstone) the Audio Optimizer app will pop up automatically and prompt to be installed.
    Of course only when Advanced Sound settings are enabled (for instance when using a receiver).
    That's only one time!
    Of you ignore that sound codec to download, it never come back. That's why they developped audio optimizer app.
    some people igonored to download the codec. And only comes back when you remove mol and reinstall it.
    But the simpliest way is to download audio Optimizer cause some people don't know what a codec is. Then they ask on forum that they have nl sound at some channels and or vod/series.
    There is audio optimizer for.
    Hello F_Peter
    Assuming this beta does not apply to MOL3 ? I just tried and no beta available. If not, will a beta release for MOL3/Z11 Pro Max be made available? Thank you.
    ** My apologies, I just realized this is not the correct forum to ask, sorry.
    Goodday my friend,
    No this is posted in the Z10 serie forum thread.
    If it comes to mol3, can be good yes.
    But that answer can Peter give you.
    As far as I know.. its an app problem and not a box/Memory issue.... So I think it should be rolled out to all boxes that will handle it...
    Z8... Z Alpha.. and the Higher spec 10s ad 11s!
    I ment to say that i think only z10 get the update and not the z8 cause z8 is lagacy. Again, i think that.
    Z11 and z12 has not mytvonline2 but mytvonline3
