finding the URL
  • He`s stopped giving it out now m8
    Why dont you threaten him with going to the police?
  • I mean,
    You have a password, username. And no URL?
    How stupid is that?
    And unfortunately we cant help you in this case!
    Do you know other users?
    did you saved it anywhere else? Old device with tivimate or phone app?
    Sorry stupid provider
    SAM i think we should close this.
    We cant provide the URL.
  • This is quite normal. Many providers have moved away from providing a url as they’re a security risk.
    Most “providers” or “resellers” have options in this case which means providing apps with DNS controlled by a panel seller side and therefore only allows you to use a username and password to log in.
    Same for Formulers, providers can have access with Formulers permission to use the option for custom config in which the url is hidden and the user again logs in with just username and password. The custom config is deployed to the end users device.
    If your seller has not provided this option and simply told you no url, it’s poor form on their behalf. Either thy have no experience of Formuler devices and or don’t know about configs or they’re simply being difficult.
    If you’re connecting via XC login then you can’t retrieve the url.
    If you connect via M3U / Stalker you can’t retrieve retrieve it but I’d hazard a guess your supplier won’t provide M3U because they too are a security risk and many have moved away from them and solely using XC.
