Hi, I tried MOL2 app custom profile code but what it seems like it completely wipe out all existing data when custom profile updates. If provider updates custom profile and you update from box by "apply&reset" it should keep its all existing current apps and last saved working username and password as its just an update of current same provider custom profile. But simply wipes all old data and asking to re enter same username and password. Is this how it meant to be on same provider custom profile update. There should be an option only to update custom profile without reset so it can take new custom profile server URL and keep old saved user ID and password and all other existing installed apps and current setup data.
when we do software update it keeps all existing current data and current profile saved url, username and password. No problem with software update unless we do factory reset. Thats the same logic should be implemented on custom profile update from same provider custom profile.
