BT3 Remote Control and OK button for my TV
  • I have a BT3 remote control and programmed this with my own TV buttons.
    Question is now how do I activate the OK button working on my TV when pressing OK on the BT3 remote control.
    All other functions (like sound, power) are working, but I need to know how to activate the OK working as the same as from the TV remote control.
    Ok button can't be programmed.
    Working only with the box!
    With mytvonline3 and with play store etc.
    The whole control of the box can with ok button.
    Your tv can with side buttons volume bar up an down.
    And button upper left corner power on and off tv.
    Goodday my friend
  • I need to know how to activate the OK working as the same as from the TV remote control.
    Open Formuler Remote app > Go to "Setup IR Control" and select your TV brand.
    After everything is programmed, press and hold the TV/STB button at the top of the remote until the light blinks red 3 times.
    Now the majority of the buttons on the remote will control your TV (including the OK button).
    Press and hold the TV/STB button until it blinks 3 times again to toggle back to controlling your Formuler.
  • Open Formuler Remote app > Go to "Setup IR Control" and select your TV brand.
    I knew that. But not that you could also use the ok button on the remote. Again learnt something.
    Thanks.
    Thanks, I didn't know this. 👌
