Hi tv guide is as normal but nothing is playing just blank screen
Not playing
- Z11 Pro-BT1
- MYTVOnline3
Tubbytoby -
November 9, 2025 at 10:51 AM
You post this in mytvonline app forum.
If you have Formuler box, with same subscription for tv.
Is it completely off?
Have iptv subscription got it working by restarting the box but now it is doing the same shows everything but nothing plays just blank screen
Please more Information!
1. Which Box,
2. What are you using as protocol ((Stalker MAC/ID, XC Api with login data or M3U playlist)?
3. Did you insert the url and data (user+password) correctly? Recheck.
We are not Magicians, please give us more issue data as possible so we can understand what goes wrong on your side. Thx.
Z11 pro max bt1
Using xcapi all information is correct was working fine and now nothing playing all epg and vod looks fine just doesn’t play
Z11 pro max bt1
No extra devices with same subscription?
Asked provider already if they have an error?
Did you try change dns to 9.9.9.9?
