Z11 pro max
  • Hi i have a z11 pro max bt1 it worked perfectly a few month and now its stuck on firmware update , i did try recovery mode with pinhole it doesnt give any result and keeps going to firmware update process then gets stuck . I did try to reach the resaler but he doesnt reply at all , i have a bill with serial number , do you think i could do anything to make it work again or to claim my warranty directly through formuler ?
    Thanks i advance for your help
  • HI,
    Please explain stuck. Can you please make video or screenshot from error?
    Can you make with your mobile phone a wifi hotspot?
    Connect with your z11 to your phone wifi hotspot and try update again.
    Maby it helps?
    It's a try worth.
    Goodday my friend.
