Official Firmware Update - v. 12.10.06 for Formuler Z12 Ultra
  • Its exactly the same Google account.... same vpn router.. same remote...
    One box will find the apps the other wont!
    I think I have the APKs on a USB somewhere......
    Strange my friend, hope you find the usb. Same account and boxes but the apps are not to find on one box🤣
    And or try to remove latest updates from google play store. Maby is one z12 play store updated and had a bug that some apps are missing?
  • How to put a channel in my favorites? I like some channel but I cant put thema in a favorite list.
    Greetz Peter
    Select the channel and press the blue button, the asterix in front of the channel name is the icon that indicates the channel is added to a favorites list.
    Or go to the favorites menu option and follow the prompts on the screen.
  • I have a reproducible problem with MYTVOnline 3 on my Formuler Z12 Ultra.
    The issue:
    When I pause live TV / a movie and leave it paused for a while, then press play to resume, MOL3 does NOT resume playback. Instead the whole app restarts and throws me back to the home screen. A short pause is fine — the problem only happens after a longer pause.
    Important – this is hardware specific:
    I moved from a Z11 Pro to a Z12 Ultra. Same IPTV provider, same portal, same MAC, same microSD card, practically the same settings. On the Z11 pause and resume always worked flawlessly. On the Z12 Ultra the app restarts on every resume.
    What I have already tried (nothing helped):
    Buffer changed from Short to Long
    Disabled "Metadata API" in Player Options
    Switched Timeshift/DVR storage between microSD, USB and the internal 128GB storage
    Cleared MOL3 cache and rebooted the box
    Disabled HDMI-CEC, set a fixed resolution, disabled Dolby Vision/Adaptive HDR
    Static IP instead of DHCP
    Factory reset
  • Please reboot the box once and after first reproduce send instantly log file (Report Problem) to Formuler and post your Tracking No. here in this thread.thx.
  • Possible clue – LAN vs WiFi:
    I think I have noticed something important: the app restart on resume happens ONLY when the box is connected via LAN cable. When I connect over WiFi instead, resuming after a pause seems to work fine. I am still testing this to confirm, but it looks like the issue may be related to the Ethernet connection on the Z12. I will report back with more results.
    Edited once, last by superdarco: Update – WiFi also restarts after a longer pause: Update on my earlier note about LAN vs WiFi: unfortunately the WiFi connection is not a solution either. After a longer pause, the app restarts on resume over WiFi as well. So the problem happens on both LAN and WiFi — it just seemed better on WiFi at first, but with a longer pause it restarts the same way. It looks like the connection type is not the cause after all; the issue is in MOL3 handling resume after a longer pause. (June 4, 2026 at 7:05 PM).
  • GTV-BT3 remote – Samsung missing from Setup Volume Control:
    During the GTV-BT3 (Formuler BT Universal) remote setup, on the "Setup Volume Control" screen there is no Samsung in the brand list. I have a Samsung Q90R soundbar and I want the remote to control its volume, but I can only choose brands like Marantz, Denon, Onkyo, Yamaha, Pioneer, Sony, Philips, Harman Kardon, etc. — Samsung is not on the list. Could Samsung please be added to the supported brand database for volume control? Without it I cannot set up volume control for my Samsung soundbar.
    Search for samsung.
    The showed list it's not the whole list😃
  • Hi, just a polite follow-up on my earlier report — I don't want to duplicate my previous thread, so I'll keep it short.
    The MOL3 issue on the Z12 Ultra is still happening: after a longer pause on live TV or a movie, pressing Play does not resume — the whole app restarts and throws me back to the home screen. Short pauses are fine. I've already gone through all the steps suggested before (buffer long, metadata API off, Timeshift/DVR on microSD/USB/internal, clearing cache, HDMI-CEC off, fixed resolution, Dolby Vision/Adaptive HDR off, static IP, factory reset) and confirmed it happens on both LAN and WiFi, so the connection type is not the cause.
    Important: I run several Z11 Pro boxes too, with the exact same 1:1 setup — same provider, same portal, same memory card — and on the Z11 Pro everything works perfectly. The problem only appears on the Z12 Ultra. So this clearly points to something specific to the Z12 / MOL3, not my configuration.
    Do you have any new ideas, or is a firmware fix planned for this? And out of curiosity — when is the final release of MYTVOnline 4 expected? Are we talking weeks, months, or still this year? Thanks a lot.
    could you please send logs after reproducing the issue? If you can also provide a video of the issue, please do so. You can upload the video to streamable.com and send me the link to it.
  • Hi 2 things every time I open myonlinetv4 it's says to turn debugging off but it's already off. And also on main TV guide some of my playlists are not showing epg but checked on other devices and there are fine .
  • Post by Pirki020 (June 26, 2026 at 3:29 PM).
    This post was deleted by the author themselves: Not the good forum page (June 26, 2026 at 3:50 PM).
