Error message
  • Hi when I try to connect to my url portal and I get an error message messages and I did reach out to the provider and they say everything is good but u still can’t access it and I try to go on u tube and that won’t work either none of my apps work what would cause this The content cannot be displayed because it is no longer available.
    Check your internet!
    Put in utp/ethernet cable and go to internet settings on your box.
    Click on dhcp then.
    There you should see then an ip address.
    Test first youtube, if that works. Tey your tv subscription.
    Or try it with wifi, but that i won't recommend. But you can make 2 different internet connections.
    Or you choose for cable/utp/ethernet. (My advice)
    Or use wifi.
    And try it with ipv6 on and off. It's on the buttom at internet settings on your box.
  • Hi I connect with an Ethernet cable and I clicked dhcp and when I remove the Ethernet cable it won't work only when I'm plugged in why you tube don't work when Ethernet cable is plugged in either so can I use the Ethernet cable
    Why remove ethernet cable? It give you fast and stable internet🙈
    Don't take it personally!: but why buy a box and tv sub if you don't know how it works?
    Edited 3 times, last by Lucky133 (March 12, 2026 at 11:11 AM).
  • Why remove ethernet cable? It give you fast and stable internet🙈
    Don't take it personally!: but why buy a box and tv sub if you don't know how it works and what to do? Correct me if i'm wrong. I'm also a human...
    He will take it personally as he expected to have bought a "Plug and Play" box,not everyone is an "Enlightened" like you,but i understand your frustration in this specific case,so stay yourself as a very helpfull human:winking_face:
  • He will take it personally as he expected to have bought a "Plug and Play" box,not everyone is an "Enlightened" like you,but i understand your frustration in this specific case,so stay yourself as a very helpfull human:winking_face:
    It's not the frustation. Bit plugin a ethernet cable and have internet and then plug it put? Then you got no internet.
    Sorry Ples123 please use ethernet cable for fast and stable internet please.
  • Maybe he want to use WIFI but didn`t explain well. How ever it is unclear what exactly he try to do/ or change and the reason for that.
    Ples123, please use google translator and write exactly step by step in your native language what the issue is, post translated in English here again.thx.
