MyTv Online 3 will not accept 1 server, have 5 other servers running okay.
This 1 server works on TiviMate, and IPTV Smarters no problem.
Any ideas ?
Thanks,
Mark7
Any ideas ?
Thanks,
Mark7
Sorry, but you give us zero info about your portal to give some suggestion.
What happens, do you get error? Which protocol in use? Url insert checked twice? Url standard, shortened or special? etc.
404 error, XCAPI,, url works on tivimate and smarters
please let me know if you need anything else
thanks,
Mark7
404 error means: The server is reachable, but the specific page requested does not exist. The portal with this url doesn`t resolve.
If you 100% sure each typo is correct inserted, try to change your dns to Mullvad or Quad9. This could help but only if url/ user and pass. are ok.
Alternative ask provider for new url and data.
I know what 404 means, I have 5 other servers running on MyTv 3
This is not a DNS issue. It works fine on tivimate or smarters.
it seems to be a compatibility issue with mytv 3.
Just wondering if you have encountered this.
I would like to keep all servers on mytv 3.
Thank you for your help.
Mark7
Any ideas ?
Thanks,
Mark7
The difference between IPTV players mainly comes down to:
the User-Agent
cookies
Stalker-specific headers
the handshake/token sequence
It’s also worth checking whether you are using the same server with the same IP address.
Display MoreI know what 404 means, I have 5 other servers running on MyTv 3
Mark7
Calm down please. We are here to help you my friend.
Can you type your url here? And hide the credentials with xxx etc.
Maby it's just a stupid slash / and or credentials like L is l or i etc.
Url you can teatv yourself is browser. Its says then: unautorized.
Some urls has :80 begind it. Remove etc. Try please.
Hi guys,, not upset, just confused. Thank you everyone for your help.
Removing :80 did not help, same 404 error
I can't figure out why tivimate and smartrs plays the same url
I have sent tickets to the server, but they don't know why it doesn't work on mytv3 either...
I have another server from the same provider that works fine on mytv3
It works on buzz5 as well, on another box
I can send the url and username and pasword, but it would need to be a PM, not in a open forum
Please let me know if anyone can help
Thank you so much for your help
Mark7
With the full url it says it's loading channels, VOD, and tv series.
it just will not play them on mytv3 only, 404 error comes up.
Only app that does this
Thanks,
Mark7
You tried a lot. On of us should find the faulth
