Hi, recently bought the S mini. I had high hopes for the box but have to say I'm really disappointed. The box refuses to wake from standby if left for a long period of time. I notice from searching different threads that this is a problem on the Z7+ is this the same issue? Are there any measures I can do to stop it from happening? The EPG is awful, another issue I have seen reported on the Z7+. The satellite channel scan is a complete mess, Channels are in no sort of order and adds lots of the same channel in no sort of order whatsoever. This is pretty basic stuff and really should have been sorted before the box went on sale. People shouldn't have to wait for software updates to cure basic stuff like this! ![]()
Standby and other bugs
- Miscellaneous
- S-Mini
spudnuts -
April 16, 2018 at 4:18 PM -
Great support forum, posted 24 hrs ago and no reply! Cheers.
du musst eine Frage schreiben um eine Antwort zu erhalten, und nicht nur deinen Frust ablassen
I Don't speak German, but I can see 2 questions in my original post!
This if fixed in upcoming update, should arrive in a few days
I think the update is for the z7+. Does anyone know if theres any beta software on the horizon for the S series?
Once released, the update will be available for all Z receivers for sure and I would imagine a similar release would go to the S series receivers if they are having a similar issue.
The devs. working synchronous also on S series and teleport all bugfixes from Z to S and reverse if requered, manosteel was right. Good news are, they have improved DVB EPG like i heard.
If you have problems with stuck on standby, try with "power off" holding OFF button more then 2sec. until bugfix come.
Btw. i don`t have release date for next update. First will come Beta and then announced on forum. -
@SAM by Beta, you mean another beta? Like Beta#3 ?
We are here in S Turbo forum, please don`t mix the Boxes and infos about them.
At moment have Z Series and included Bugs priority, the Beta for Z Series is now Beta2.
I spoke in my last post about S Series and that Beta will come first before official release goes OTA.PS. Even the thread starter made mistake and posted in S Turbo forum. Thread moved to S mini forum!
