I purchased 2 formuler Z7+ and think they are great except for the WIFI Adapter that came with them they fail to connect to either of my 2x 5g wifi channels always says connection failed but ever once in a while they connect but never stay connected...
Any help would be appreciated.. My router is a netgear AC3200 . I have no other issues with any other device connecting???? ![]()
Z+ Wifi
- Miscellaneous
- Z7+
Ragu -
April 28, 2018 at 2:06 PM -
The following USB WiFi adapters are compatible with Formuler Z7+.Folgende USB Wifi Adapter sind mit Formuler Z7+ kompatibel.
RTL8188EUS
RTL8188ETV
RTL8812AU
HI1131C
RTL8188FTV
RTL8192EU
MT7601U
RTL8723BU -
The US formuler comes with an external USB WiFI so it's not a matter of compatibility.
Try changing the 5GHz channel on your router. If it's set to AUTO try changing it to 149 or something similar and see if that helps.
hi i am from germany and also use a usb wifi adapter. i have one from gigablue 600mbit..
i (have) also the same problem, the wifi doesnt stay connected, every 4-5 hours it disconnecs sometime every 1 hour. but now i think i have a solution. i also write with a other person in the forum. he told me that he disabled the ipv6 firewall an give your box a static ip in your router.he used the box for 24 hours and it no disconnecs.
me i tested it today an i had also no disconnect problem.
i will test is and let you know..(hope you understand my english
Try the D-Link DWA-182. I was having the same issue with the supplied W2 adapter. You can find on EBay for $5
