will usb 2.0 work for recording
Usb 2.0
- Hardware
- Z7+
johnpd -
July 4, 2018 at 8:58 PM -
Of course.
So i can insert 2.0 usb into 3.0 on box. Sorry for stupid questions.
Of course 3.0 is downwardly compatible to 2.0. What changes is only the speed, because the 2.0 USB device is slower then USB3.0 device but for stream recording fast enough.
thanks for quick reply
last question. Do i need to format
Format the USB Device with NTFS on PC and plugin, restart the box and you can start at once with recording.
followed your instructions.
Just get a warning message "usb storage not found"
Then is something wrong with your format or the USB Stick. I suggest, download "Tool Rufus" from web and format with this tool. You didn`t also say what kind of device this is: Stick, hdd?
its a usb 2.0 64gb. I just tried again. Im just trying to record channel im currently watching. Pressing red. It also wont pause. Just getting used to box. Apoligies
If i understand correctly, it works, right?
lol. Sorry. Usb was faulty. Tried a different stick. Works perfectly. Thanks for your time
Thx for feedback.
Hello SAM this is bill. A little confused. I thought you said we could use a Fat 32 SD card Sandisk for recording.? My wife doesn’t want to buy HD because this card is fairly new. I have it in and it shows up in storage as shared storage or SD card for movement of only some apps. Haven’t tried recording yet!!!! Thanks for your help. Hope all is well. 😀😀
