With the lastest update The EPG takes longer to load. What happen? In the EPG guide scroll channel says “no information” then finally shows...
EPG loading time delay after update.
- MYTVOnline1
- Z7+
Rickiev -
October 22, 2018 at 8:48 PM -
Same thing here.....
hello my friends.
An option is to delete the mytvonline app and install mytvonline 1.9.48
Don't forget to note your portal url on a paper, you need it again after reinstall.
How:
Go to settingswheel and then to system.
Typ on your remote code: 0227
You see a message testmode enabled.
Exit and go to formuler market.
At top10 you see mytvonline 1.9.48
Click on it.
Click on uninstall
Click now on install (after uninstall)
Now you have 1.9.48🤗
Don't update to 1.9.55. It has also epg problems.
Display More
hello my friends.
How:
Click on it.
Click on uninstall
Thanks, the only available option was 1.9.52, no 1.9.48 - .52 also has a delay in epg showing.
It worked for me. Installed 1.9.48 no problems.
I've backed up the .apk (10Mb) so if you have somewhere for me to upload it to it's all yours.
Rickiev you have PM.
I installed 1.9.48 after doing my full factory reset to fix some buffering issues I had and this version has the same problem with MAC portal, it’s actually taking even longer now than 1.9.55 did however since the app hasn’t crashed once on me since installing 1.9.48 after it crashed 3 times today on 1.9.55 I’m thinking I will just leave it alone until the next MOL release comes. My MAC provider is my least favorite so it’s not a big deal for the moment.
Maby you have dont follow my steps.
I follow the steps and indeed EPG is back!
Thanks.
I don't install the iptv version v1.9.52 for the moment.
I did exactly as Lucky said but as Rickiev, i don't have the option 1.9.48 in the market.....
An idea...?
An idea...?
Go to system.
Put 0227 on your remote
DO NOT REMOVE MYTVONLINE!!
Go now to market.
NOW YOU MUST see mytvonline .48
Go to the app.
The click on uninstall.
And now on install.
Try again my friend
Just a question: can we update the Firmware Version: v2.8.49 without risk for my tvonline?
Do we stand to the old version of my tvonline?
Yes if only the firmware is showing.
No if under firmware the mytvonline app stand.
Otherwise follow my steps to downgrade to older my
Tvonline.
Let me know my friend.
The firmware is showing: so, i can do the update.
My tvonline is now 1.9.52 and it works.
Thanks.
Thanks.
Great job!
