Storage: Micro SD and Internal
  • I have a 64 GB Sandisk Micor SD card. All though nothing was/is recorded or, to my knowledge, stored on the card it showed 29 GB used. I reviewed the card contents using various apps, File Explorer, Total Commander, and ESFile Explorer, but could find nothing that would come close to taking up that amount of space. I removed and reformatted the card and it now shows 307 MB used however the internal storage now shows as 5 GB total. Shouldn't the internal be 8 GB? I had assumed that an app was using space on the card that I was unaware of and it was hidden. Now I'm just confused.
