pause works but play doesn't?
  • I've developed an odd problem. When watching either live or catch-up TV, the pause button works to pause, but the play button doesn't work to resume. (Nor does re-pressing the pause button.) The only way to get things working is to change to another channel and then change back.
    This just started in the past couple of days. Before that, it worked as expected.
    Any thoughts? Thanks.
    Edit: OK, I just found a workaround...The stop button causes play to resume (paradoxically). This isn't the expected behavior, right?
    Closed the thread.
    Removed the Label wcf.acp.label.label6
