Why the MYTV or the Z7 is so bad compared to the other devices? I have in my house another device with the same server and it does not have any buffering. in the case of z7 has_many buffering. already tried the mag 254 mag mag 322 the MXQ and even iptv apparatus 30 pounds and are all much better than the z7 +. a complete disappointment and loss of money.
MYTV buffering and z7+ so bad
- MYTVOnline1
- Z7+
Varela -
December 22, 2018 at 1:13 AM -
You apparently have no idea what you're talking about This is the best IPTV box currently on the market.
sorry but I have not found a reason why this is the best in the market. after an hour or two watching TV( wht some brufferings) it is impossible to continue because it is buffering permanent . Looks like the box disconnects from the internet. I use exactly the same provider in other boxes in the same place of the house and it works everything without any problem.
I have seen some Z7+ with really bad internet speed connection. Even using good quality cables, usually these boxes get better speeds on WiFi wich is hard to understand (not all boxes, just the ones that get low values on connection speed!)
Don't know if this is really an issue as I have few of these boxes and not much available time for watching/testing.
I always recomend using wired connection but some of theses boxes really seem to have faulty ethernet boards, or similar problem with wired connection.
I use http://www.fast.com for testing speeds.
Does anyone else have similar results?
Best Regards
I use a wired connection with my Z7+. I get about 20 MB/s without a VPN and 15 MB/s with. This compares to 200 MB/s on my laptop (via wifi).
So overall, I'm not impressed with the connection speed on the Z7+. And the issue may be more with the intrinsic hardware than with its wifi abilities.
Did you guys try to change to static ip?
I am using a static IP.
Same problem here. I even bought a usb3 to giga netwotk. Same problem! When I playing VOD and when I try some 4K movies its buffering all the time.
4k tv streaming will even not start! I have a 500/500 line, so the conection is not a probklem. Now i bought a MAG 322 and all works perfect even with 4k streaming with live tv and VOD. Sorry, but I think the hardware in the Formula is to weak.
Exacty mate. I bought a MAG 322 and all works perfect too.
