There is HDMI CEC on Z8 ?
Yes
Today i will upload bunch of Screenshots ![]()
HDMI CEC don’t work for me. I have a Samsung tv UE46E5300. The message error is : « Anynet+ can’t connect to Formuler Z8. Please verify and try again ». Any idee to help me ?
HDMI CEC also not working for me, it works fine with rp3 libreelec.
TV Samsung 60J6240
Did you test another HDMI cable?
Yes i did. But no changes.
Works on my TV.
Samsung UE48J6375SUXXE
works on my TV Samsung TV QLED 75Q7F 2017,
but very low
does not work on my LG TV UJ634V
LG Oled 55 C7D works fine.
When you turn on your TV by the TV key of the Z8 telecomande this also lights the case?
I understand what you mean. Tested now all possible modi, turn off with TV RCU works but not on, even if the tv search on same HDMI port. Will forward this to Formuler.
But you know we don`t understand French?
Sorry it's Google that's elite.So when I press TV it turns off the TV and the z8.When I press TV it does not light the z8 I have to press stb same if I press first on stb it does not turn on the TV
Yes, i saw same in my test. Will forward to Formuler devs.
I also just noticed that if I want to turn off the whole it only works with the TV key.
The stb key only shuts down the Z8 but not the terminal.
