2 Different Devices can't even see any Wifi AP
  • Just another constant issue with Formuler 7Z+
    Neither can see any wifi's to connect to - did factory reset a few times and both the same.
    I have an old iPhone 2C that can see more than these devices.
    How do I go back to a working version of software for this?
  • did this several times as well. I looked and no updates available. I turned off and on. removed the antenna and rebooted and various combinations. Wires it works with no issues, all of this happened after the last update. First at random times it would lose wifi connection and now it can't see anything.
  • I too have noticed the Formuler z 7+ has problems with wi fi drops the connection lots it is too bad this can't be fixed as that is where I can get the fast download speeds on the 5 ghz wi fi but when it loses connection get buffering etc. so have to use the wired connection which gives slower speeds. I was thinking of buying the formuler z8 as it would allow for the faster speeds wired but I keep checking on here and seems they are having lots of problems with that box also. I also thought the z7+ only has wi fi through the usb adapter that came with the box. Also I noticed since last update the resolution button on the remote no longer works . I hope Formuler comes out with an update to address all the issues. I think when and if they get all the bugs out these will be good boxes as the option to record the nice guide that comes with mytv app are nice they just have to get it working proper no buffering ,fix the wi fi connection issues etc.
  • yea while I love the device it is not consistent and various problems happen all the time. right now i have a cat5 cable running thru my house but I hope to get a fix or find a new device. you think that many people reported the same issue they would say there must be a wifi issue?
  • I see now Formuler now offer the with built in wi fi
    New Formuler Z7 plus 5G Premium UHD IPTV set top box with Android 7 Nougat
    Introducing to the North American Market Formuler Z7 plus, now with built-in 5G dual band wifi and Bluetooth.
    So all the people who bought the Formuler Z7+ that came with the plug usb wi fi dual antenna seems to me like they know now from all the people who complained about wi fi connection problems they came up with a way to fix it by making it built in. That doesn't really help the people who have the original version that wi fi isn't bulit in . I guess thats why they ask is your wi fi built in or not. Would be nice if they would offer to exchange out the original boxes for the new version with built in wi fi to fix all the connection problems.
