Goodnight, I've been having problems lately.
with my form, they are active and not
they call the provider.
Can someone answer me?
What do you mean? Hard to understand your English is a bit weird.
If i understand well, you don't get connect to your provider. Did you contact your provider and ask them?
Yes, I asked but they say it is a problem of updating but I do not believe it.
I already sent a message to the factory, because if I connect a tvip it connects to the same account, and the formuler does not.
Mytvonline 1.9.72 is not picking up, a message appears check your internet connection or URL. being that the internet is catching normally. Someone can tell me how to pack. is not opening any channels.
Mytvonline1.9.72 is not picking up, a message appears check your internet connection orURL. being that the internet is catching normally. Someone can tell me how topack. is not opening any channels.
First Install latest Mytvonline from today 1.9.73.
How do you connect to your provider, MAC/ ID registration, Xtremecodes Api with login or M3U? Country Brazil?
BTW, which box do you use Z+,z7+?
This friend, I'm from Brazil. My device is Z +. I do not know for sure but I believe it's MAC / ID registration. You could help me upgrade to 1.9.73, because here the update did not arrive by itself.
Could you check Brand/model from bottom of your product? Picture from Label (without MAC and Sn!)
Are you able to contact local dealer?
