I install the Netflix from the store of the Formuler Z7+.
When i lunch the application says New version find it (update or cancel), if i click update appears a error something like this: This application is not compatible with your device.
If i click cancel i can open the Netflix. There is a problem that i can know work around. I choose a serie and the session that i wanna see and if they are many episodes i try scroll down to chose the episode that i wanna see (the menu goes out of the screen), but i can´t do it.
