Is it possible to make own favouritlist and change channels in which order i want in next update?
Favouritlist
sparren -
June 20, 2019 at 11:02 PM -
No, this feature will not be included in the upcoming update as I'm aware of but there are other methods.
Yes before u could do it on xtream editor but now they change so u only can change countries
Is it coming later this year?
If this is planed or not can only answer you 175n.
Is there any who know where i can do my own list?
What do you mean? I use XE and have edited my own playlist.
On xe i can change order of countries but not the channels anymore
To be honest yesterday I edited my playlist and moved a couple of channels.
Ok i have to talk with my provider again, because i get the xe line from him, but before it worked perfect to change
Now i have only the lines on left side on countries but not lines on channels
You should contact the XE support team to help you out.
