New firmware and software update for S-series devices has been released.
Download the latest S-series update from the Software Download menu in your device.
Firmware Version : v1.6.54
MYTVOnline Version : v1.9.79
WARNING: Software cannot be rolled back after installation.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer then usual, please be patient and let the box finish the install.
Change Log:
Firmware Version: v1.6.54
- ADD : C-BAND LNB 5150/5750 for single solution LNB's
- ADD : Multi satellite scan feature
- ADD : Weather widget revised
- ADD : Weather search by city names
- ADD : Delete, rename option in File Manager
- ADD : While scanning satellite, it will show the name of satellite
- ADD : Bluetooth and power mode shortcuts added to the main menu
- IMP : File playlist browse, delete options
- FIX : Bluetooth connectivity issues
- FIX : Pause video in timeshift shows Service Error
- FIX : TTX subtitle of IP channels not working
- FIX : Device crashes when T2 signal is low
- FIX : Force closing of certain APK
- Various bug fixes and performance improvements
MYTVOnline Version: v1.9.79
- IMP : Increased refresh rate of detailed stream info
- FIX : Radio channel streaming issue on certain portals
- FIX : Episode playback issue on certain portals
- FIX : Crashing issue when switching portals
- FIX : Favorite list changes if m3u list is updated
- FIX : Page scrolling issue in TV Series section
- FIX : xmltv EPG parsing issue
- FIX : Cell overlap issue in Program Guide
- FIX : HLS VOD playback issue
- FIX : Group Channel Numbering preference changes after applying Installer Mode config
- FIX : Recording stops if stream buffers
- FIX : m3u channel parsing issue
- FIX : TV Series playback/seek issue
- FIX : Favorite channels disappear when using Xtream Codes API
- FIX : Timeshift file is created on USB even if Timeshift is set to OFF
- FIX : HLS streams don't auto-recover after network instability
- FIX : No sound issue when returns to SAT channel from mytvonline by IP/SAT button on RCU
- FIX : Image retention issue after closing mytvonline and returning to SAT channel
