Epg issues Xtream -editor
  • I can see formuler like when you buy their products but do not like answering questions same for xtream codes. Think I'll be bringing back buzz tv box as response at least I get one . Since update formuler or xtream editor keep blaming each other for reasons why no epg loads for portal on xtream . Nothing to do with provider as other apps load epg I should not pay the prices in pay for mytvonline as let's be real I pay over 100 for the app only as nothing else different from 40 andriod except the customer service is prob better on cheap box. Bottom line fix your bugs you charge people for
  • formuler doesn't allow catch up on playlists section on portal neither does reminder work either to have full access I use mac portal which you load your details onto xtream which then turns into mac address . This was working up till they had a issue with xtream editor portal which was rectified now I cannot load epg unless opening epg window and scrolling through plus when I press remind on channel it crashes my mol. Xtream have messages and said formuler are aware and will issue a update in next few days however I have not read that anywhere else so I'm assuming someone is telling none truth lol
  • I am getting this problem since 23rd July of no EPG showing or loading unless i scroll through SLOWLY via the EPG menu it then populates very slowly both on Mac portal and m3u playlist options, i have a different provider on each option and both are fully loaded when i use them via Tivimate app.
    Firmware version: v1.2.71
    IPTV version: v1.9.80
    So far have done the obvious troubleshooting from my end- deleted EPG and cache and factory reset to the box.
    Looking through both the Z7+ and Z8 forums there seems to be many users experiencing this EPG bug, so is there any chance of a fix in the very near future, as the "hotfix" you mentioned above does not seem to have done much good?
    Regards
