Xtream-Editor subscribers & MOL2
  • I'm currently using XE & m*g because it offers catch-up. It's currently the best option if you use XE & MOL2. But m*g can not use more than 1 connection (it's a m*g limitation and nothing to do with either XE or MOL2).
    I would prefer to use M3U with XE as it normally allows you to use more than 1 connection (ie watch & record separate channels, but not currently available in MOL2). I also find that the tv guide loads much faster using the m3u/xmltv system. Also no catch-up currently available via m3u on MOL2.
    XC Api allows catch-up, time-shift, more than 1 connection (but not currently via mol2), extra information about your line (subscription length). But it can't be used in conjunction with XE as XE does not provide a username & password.
    I suppose if you could fully edit groups and channels in MOL2 then XC Api would be a great method if your providers own tv guide was any way half-decent. There would be no real need to use XE in that case.
  • Use M*G if you want to use the catchup but you have to pay for it. I use M3u link because I don't use catchup and plus it's free.
  • Im a bit confused about this topic,..I use the following method to load my service in the playlist section on MTOL Z7+, the bottom line pulls in the epg.
    http://EXAMPLE_url/get.php?username=EXAMPLE&password=EXAMPLE&type=m3u_plus&output=ts
    http://EXAMPLE-url/xmltv.php?username=EXAMPLE&password=EXAMPLE&type=m3u_plus&output=ts
  • How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
    Take a minute and look at this article I think you will find it useful.
    Well smack me in the mouth with a wet fish!.....I never knew that could be done in MTOL, just tried it & it works 100%, pulls in everything including live tv,epg & catchup,...even VOD, just needed to enter the relevant info from my m3u line & bingo,....many thanks
  • You're Welcome :smiling_face:
    m3u/XC method is useful for me as I can use the same connection on a small firestick when on holiday with another well know app, where as using a mac address method isn't as portable, I also have mac connection but for home use on the z7+,...thanks again.
    hey! where do you pull the relevant info from to get it to work on portal? do i use xtream editor the EPG URL and M3U URL? what exact info do i need from there to plug in to portal on MOL2
    Have you been able to use portal through xtream editor? Not sure what info i put in to the portal area as xtream editor provides me with nothing
  • Have you been able to use portal through xtream editor? Not sure what info i put in to the portal area as xtream editor provides me with nothing
    Yes, you can do that. I use xtream editor.
    Use: http://m*g.xeev.net/mol (you might have to remove "/mol" in order to work). Here is direct link
    Username : Your xtream editor username
    Pass: Your xtream editor password
  • Yes, you can do that. I use xtream editor.
    With this method, you’re purchasing an m3u subscription from your reseller and not a m*g subscription correct? Also the username and password are the same that my provider gives me?
  • With this method, you’re purchasing an m3u subscription from your reseller and not a m*g subscription correct? Also the username and password are the same that my provider gives me?
    Sorry for the late response. There will be two separate subs, one from your provider/reseller and one from xtream editor (to use their services).
    Xtream editor considers formuler as m*g device for some reason but it's not an actual m*g box.
    Do you currently have any iptv provider sub?
    The only reason I use xtream is because I can rearange the channels the way I like and not for their epg service.
    Mind you, xtream asks 19 swiss franks/year for use of the playist editor. Using m*g device is an addition 5/y, if I remember correctly.
