Just back from holiday. Cannot connect. An error "code11" is being displayed. Worked perfectly 10 days ago. What has happened and why ? Very frustrating
Code 11
orm123 -
August 24, 2019 at 6:16 PM -
Where does error code 11 displayed? Maybe something to do with your provider??
It gets displayed after trying to connect. It is nothing to do with supplier as works perfectly on Z8 after I downloaded IPTV Smarters to box.
Not ideal, as I want to use Mytvonline2. Could it be anything to do with latest update?
How do you connect with your portal m3u or MAC/ID? Did you ask your provider if something changed in the time you was in holidays?
I connect with M3u. Interesting my son has the exact model and was watching the football on Sunday and 10 minutes into match, it stopped working and a code 11 notice appeared.
Someone somewhere must have a list of what the different codes are?
I see you are in UK, did you try to use vpn? Please install vpn and try again.
Yes I always use a VPN (as you say, in the UK so no choice).
I am going to uninstall Mytvonline2 and reinstall and see if that helps. The last update might have corrupted to app.
Will let you know how it went.
