Hi, i have to 2 portals on my box, and i want to go into one of the ,The problem i have is that 1 off my portals is not working & i would like to go into the other portal, how do i stop the 1st portal from automatically trying to load, because it is not working, it keeps crashing and telling me to try again, it just keeps looking this way, and i would like to try my other portal, but i have no way to get into my 2nd portal, because it is automatically trying to load the 1st portal , so how can i stop it from automatically trying to load the first portal, thus allowing my to load my 2nd portal..thanks...
STOP A PORTAL FROM LOADING
- MYTVOnline1
- Z7+
wullboy -
October 1, 2019 at 11:11 AM -
First turn off the internet connection.
Then go to the portal and choose what you want.
Reconnect to the internet
Sh***...its that easy...pmsl
you can just press back button when you are in the loading screen
Or the exit button 👊🏻
Ya or the exit button. I couldn't remember which one it was on top of my head
Same here.
I use the Formuler every day, and when you explain someone i must think witch button or how😉
When i have the remote in my hand its already done😂
Thanks guys...i see it now at the bottom of the screen...cheers
Solved!
