Beta firmware 1.4.45 / Mytvonline 2 software 7.5.5 for Z8.
  • Formuler Z-Series beta released for Z8
    Firmware Version : 1.4.45 BETA
    MYTVOnline 2 : 7.5.5 BETA
    WARNING:
    HowTo Install:
    Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
    Fixes & Improvements:
    • [SYSTEM] FIX: System VideoPlayer always defaults to Fullscreen playback. Default is now 'Original aspect'
    • [SYSTEM] FIX: Remote configuration image URL issue
    • [SYSTEM] IMP: Added Automatic System shutdown notice after AC power loss
    • [SYSTEM] IMP: Added Software Update notification to home screen widget
    • [MOL2] FIX: Video glitching when using USB DVB Tuner
    • [MOL2] FIX: New episodes not displayed correctly on certain portals
    • [MOL2] IMP: Use long channel name for ATSC OTA channels if available
    Menu Translations:
    • Français
    • Nederlands
    • Deutsch
    • Türkçe
    • Español
    • Português
    • Pусский
    • Lietuvių
    Important: Translation bugs can be reported in this thread -> MOL2 and Z8 translation
  • Sometimes when you try to play a recorded program (in MOL2) it starts steaming the last channel again... and when you persist and keep trying a few times then suddenly the usb storage gets disconnected, which will become clear due to the popup message "Empty recordings".
    If you then reboot the Z8 and go into recordings all plays again. :thinking_face:
