I have a USB drive attached to Z8. It is formatted as NTFS and has a lot of free space.
MOL2 can create recording files 3G or 4G large.
When I tried to use Window 10 to copy files larger than 1G using samba, it erred with "There is not enough space on share. You need an additional xxx MB to copy these files".
There was no error when copying files less than 1G.
Anything I should change to remove such limitation?
