If i understood correctly this is only for the tile, it is possible to do same for the background behind the apps at the start up?
On a Z7+ ?
On a Z7+ ?
This is Launcher Customization video on Z7+. Shows what is possible.
Background can be only changed with provider tool calling "molcfg". Many of non technical users blocked own boxes with such tool in past, therefore we do not share this tool on forum.
On a Z7+ ?
If you are a reseller, you can use the molcfg tools to change the background.
It isn't a tool that is recommended for end-users however.
I tried it and the tool looks great.. nice to redesign the background and the app.
There is a small doc about the setup protection ? what each line do ?
I'm interested to hide the url portal name, there is a way ?
SAM, there is a way to hide the portal url ? like if someone is going into the portal only see the portal name but not the URL ?
I think there is only the possibility to lock portal so the user can not change anything. Never used molcfg in productive modus.
ok I thought i got it because i took below print screen and it works after using the molcfg because clearly mentioned URL Lock but after restart the URL was available.![]()
Read the instructions included with molcfg kit.
175n, do you mean that if you lock then the url is not shown..?![]()
Like i know, if locked you can not as user get inside and see what is inside, edit is then not possible.
Hi can someone private message me this software please?
Anyone?
If you are reseller and want this tool ask Formuler directly, we don`t share the tool on forum.
