I have a Problem After Last Update with my z8,
I can Watch iptv normaly, but the VOD can‘t load the data So i can‘t Watch anything. On my phone works all without problems.
can anyone help me?
can anyone help me?
Hotfix will be released in short.
ok thanks for the quick answer, then let's wait
Hotfix does not apply to this issue. First time hearing of this.
Yes you are right, was cross posting with no live tv channels hotfix and info ended here also.
How do you connect with your provider? MAC/ID portal, XC Api Portal or m3u Playlist.
i connect with m3u list
Use your m3u data and make XC Api Portal.
All needed data are in your M3U url.
Portal Nickname (example): XC_A
Portal URL: "http://xtremec.com:1111"
Is the login required?: yes, please activate.
Username: 11111
Password: 22222
Please read also the how to -> How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
I will try it
Display MoreUse your m3u data and make XC Api Portal.
Username: 11111
Password: 22222
I tried it and its working, thank you SAM 👍🏻
I got almost the same problem when I open vod and select movie in 4k I get eror code 7
If error code 7 is shown, then trough connecting process to the provider and not later when you are watching something.
The provider says its working on his end so am stuck,, iptv works fine and smooth, wil just leave it as is I think
i also have a problem with vod, i get the message "error loading vod list".
from my provider i get an m3u file for live tv and a m3u file for vod, seperate server.
i choose m3u connect, put both files on a stick in m3u folder and select them by connecting m3u list.
live tv is okay, by vod i get the error...
in vlc the same vod m3u makes no problem...
Try the guidance for creating XC Api portal (if your provider support XC Api), then you don`t need two url`s and have much more options.
See post -> VOD does Not Start
My Provider has only two options.
Either i can use his own portal or i get two files m3u (one for live server and one for vod).
I have also tried tivimate. There i can use live tv and vod, but by playing vod i can only use play/pause no fast backward/forward.
Ask your provider to send you the m3u link instead of the files.
Then take this, you have more benefit with MAC/ID or even more with XC Api portal. For your m3u, you need three url`s, for server, vod and epg and this is to complicated and very error-prone..
