New beta released for Z prime <> Z7+5G.
Beta Firmware Version : 1.2.97 for Zx, Z7+, Zx 5G and Z7+ 5G
Beta Firmware Version : 2.8.97 for Z prime, Z, Z+, Z Nano
Beta MYTVOnline : 1.9.97
WARNING:
HowTo Install:
Home Menu ->Cog. Wheel -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Beta FW 2.8.97 or 1.2.97 - SW 1.9.97 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
Firmware Version : 2.8.97/1.2.97 BETA
Fixes & Improvements:
- ADD: Remote update of custom configuration from URL (molcfg)
- For more details how to do it, please ask your distributor
- FIX: Android settings > Physical keyboard > Layout
- FIX: Android settings > Manual VPN config > L2TP PSK mode issue
MYTVOnline : 1.9.97 BETA
- IMP: USB DVB-T > FTA Only scan
- IMP: VOD > Scroll from first to last episode more easily
- FIX: M3U URL redirect issue
- FIX: M3U parsing issue
- FIX: VOD > All category not visible on certain services
- FIX: HLS adaptive streaming issue
- FIX: VOD playback issue for some services
- FIX: Unable to play Episode under certain circumstances
- Bug fixes and performance enhancements
