Formuler Z, Nano, Prime, Plus, Zx/G, Z7+/G
Firmware Version : 2.8.85 or 1.2.85 BETA (Device dependent)
WARNING:
HowTo Install:
Home Menu -> Cog.Wheel -> Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Change Log
Fixes & Improvements:
[SYSTEM] FIX: System VideoPlayer always defaults to Fullscreen playback.
[SYSTEM] IMP: Added ability to log out of Google Account
* Access from Android Settings > Accounts > ActionMenu > Remove account
* Mouse cursor mode required
MYTVOnline 1 : 1.9.85 BETA
Change Log
New Features:
[MOL1] ADD: Live Cloud Timeshift on supported services * Start Cloud Timeshift by pressing the |< (prev.) button on the remote
[MOL1] ADD: Hide unwanted channel groups * Access group editor from Live > Groups > red hotkey
[MOL1] ADD: VOD/Series Sorting. Sort by Newly Added for XC API portals
[MOL1] ADD: Single Channel EPG for XC API portals
[MOL1] ADD: Show current event name in channel history list
[MOL1] FIX: App crashes a few seconds after connecting to certain portals
[MOL1] FIX: Cannot connect to certain portals due to HTTP redirection issue
[MOL1] FIX: App crashes when performing VOD search on XC API portals
[MOL1] FIX: "Video can not be played" issue on certain XC API portals
[MOL1] FIX: Live > black screen issue on certain XC API portals
[MOL1] FIX: Per-channel audio track preference not saved
[MOL1] FIX: EPG Mode preference not saved when switching between portals
[MOL1] FIX: Recordings are overwritten if event name is the same
General bug fixes and performance enhancements
Known Issues:
[MOL1] EPG data missing on certain portals
