Hi Guys,
when I plug my external 2.5” HDD into the Z8 and I put it to standby the HDD remains on all the time. If I select as power option “turn off” the HDD turns off immediately. But it takes long to start the box as I assume “turn off” means deep sleep, right? Or are there other implications with the turn off power option?
is it possible to have the USB port turned off on standby as well?
Thanks for feedback!
