Official Firmware v1.7.29 / MyTVOnline v2.0.0 for S Series (04.06.2020)
  • New firmware and software update for S-series devices has been released.
    Download the latest S-series update from the Software Download menu in your device.
    Firmware Version : v1.7.29
    MYTVOnline Version : v2.0.0
    WARNING: Software cannot be rolled back after installation.
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer then usual, please be patient and let the box finish the install.
    Change Log:
    Firmware Version: v1.7.29
    • ADD : IPTV channel (m3u) EPG support on DVB
    • ADD: Satellite list editor
      • Dish setting > Edit satellite (Press Red key)
      • Edit name, Edit degree, Hide and Move
    • IMP: Weather forecast – 10 days info displayed
    • IMP: Showing numeric value on volume bar
    • IMP: Launcher error in specific situation
    • FIX: Resolution display error in Info bar
    • FIX: Service error in specific timeshift sequences
    • FIX: No subtitle display issue on live in specific situation
    • FIX: Disable mouse cursor function while system lock pop up
    • General bug fixes and performance enhancements
    MYTVOnline Version: v2.0.0
    • ADD: Live Cloud Timeshift on supported services
      • Start Cloud Timeshift by pressing the |< (prev.) button on the remote
    • ADD: Hide unwanted channel groups
      • Access group editor from Live > Groups > red hotkey
    • ADD: VOD/Series Sorting. Sort by Newly Added
    • ADD: Single Channel EPG for XC API portals
    • IMP: VOD > Scroll from first to last episode more easily
    • FIX: M3U URL redirect issue
    • FIX: M3U parsing issue
    • FIX: HLS adaptive streaming issue
  • an update box will connect with stbemu and spoofed mac. Tested on multiple suppliers. Will not work with formuler mac address and suppliers confirmed no issues on their end. Tried three boxes all same result
  • If the MAC (in Formuler case is the ID important for the Provider!) in your case not work, why don`t you use XC Api as Portal or m3u Playlist?
  • since one week my Turbo S Formuler dont connecting to my Portal with MyTVOnline.
    Latest Software from June wirkend till last month without Problems. But since a week "Cant connect to Portal" appears. Tested with DuplexIPTV the Line is working. STBemu not working - Blocked mac like another User described at this thread. I want a hotfix like users of the Formuler Z series! There was no Update and no changing and stop working. Other users same Problem. Help us!
    Problem solved!!!!
    Go to Home Menu - Software Download. There press "0227" and RED Button on remot. Installiert the Beta Firmware 2.0.4. And then Portal working great again :smiling_face:
