Hi there. Is there anyway to force playback time to not shutdown my Z8 whilst recording. I cannot seem to record over 3h. It forcibly shuts down after 3h. Therefore I cannot record any of my golf tournaments which usually is on Air between 21 - 01. This is extremely annoying. I cannot asm my provider to change this. And I want to continue using Mac-adress. Is there a way? Thx in advance /Zoolution![]()
Playback time ends during record
Use xc api instead of mac portal connection.
I dont know what that is 😀 Thx for reply
Unfortunately thats not an option for me. Just cant figure iut what its doing there anyway. What is it good for. If you want it to shutdown you should use energy saving. But ok. Someone else have any idea?
Please read this thread, same problem and solution for this -> RE: Disable playback limit on formuler z8?
Btw. Stalker connection (MAC/ID) and playback time are from provider limited.
Solution1: You speak with your provider to turn it off.
Solution2: You use XC Api portal instead of MAC portal, like Mevi posted.
This was fixed in the recent beta software release
