Formuler z8
  • In order to do this, you need either an M3U playlist or an XCodes Portal connection to your IPTV Provider. Some providers will market an XCodes connection as “multiroom” or “multi-line”, which effectively describes its purpose: enabling you to have two simultaneous connections to your provider. Recording one channel and watching another is also possible when connecting to your IPTV Provider using an M3U Playlist URL, but since those do not necessarily allow you to have two simultaneous active connections, using an M3U Playlist URL to achieve this may actually result in your provider choosing to ban you from their service. Be aware that Stalker connections are single line only and do NOT support this at all.
    A good step to begin is to contact your IPTV Provider stating that you would like a multiroom XCodes connection for 2 simultaneous “lines”, as they will most often call them. If your provider supports this kind of setup (most do) then you will receive an email containing:
    1. A service url
    2. A user name
    3. A password
    Upon receiving this email, go to MOL2’s menu and select Connections. There, select your current portal (which will most likely stop working anyway as soon as your provider activates your new setup.
    To actually delete your current portal, select it using the cursor keys and then press OK; in the subsequent menu select Delete. You may then have to confirm your choice, after which you’ll be brought back to the Connections menu.
    There, you will now select Add Connection. In the screen that appears, fill in the Connection Name (which may be anything you like), Server Name and port number (if applicable).
    Then check the Require Login checkbox and fill in your User Name and Password in the boxes that appear.
    Complete the rest of the screen (EPG Time Mode, Channel Grouping, etc.) according to your wishes and then save the settings.
    You’ll be brought back to the Connections menu once again, where you’ll select your connection and actually connect to it. Once you are connected to your working multiroom XCodes connection you can start recording as you normally would. Only now you can actually watch another channel whilst recording.
    I would probably not have to tell you this, but, obviously, recording requires some kind of storage device to be connected and configured. This may either be a USB device or a network location on a NAS.
    When using a USB device, things should be simple enough to get you started. If you run into any problems getting things to work, report back here and I’ll help you out.
  • Discussed detailed in this -> thread
    The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.
    Is merge possible?
