- Model: Z8 Pro
- Retail Box or Provider Box: Retail
- Firmware version: Unknown
- MYTVOnline 1 / MYTVOnline 2 version: Unknown
- Connection with provider: Not yet connected
- Box connected with: Ethernet
- Did you factory reset your device? and when?: No
- Picture url (only https):
- Video download url (only https):
- What issue(s) are you having? I connected the Z8 Pro to a 1080p TV. The Z8 Pro boots when turned on and then displays message that I need to connect to an HDCP 2.2 HDMI jack. I found a troubleshooting procedure on the Forum for changing resolution, but it requires pressing a "resolution button". My remote does not have that button so I can't perform that procedure.
- What was you expecting to happen? Z8 would boot and open a home page on my 1080p TV.
- What happened instead? The above message is displayed and the Z8 Pro stops.
- How can we reproduce the issue you are having? Perhaps, but you would need a 1080p TV and the version of remote without a resolution button. The issue should occur as soon as you turn on the Z8 Pro
- What have you tried if anything to rectify the issue? Don't know what to try. I have searched the forum, but can find any info that matches my issue. I don't know anyone with a 4K HDCP 2.2 TV that I could use to access the Z8 Pro menu and change resolution.
Using the Z8 Pro with a 1080P TV (changing resolution)
Mayo -
November 28, 2020 at 5:52 PM -
Are you able to reach the settings in main launcher menu?
You need to change to HDCP 1.4 on your Z8 pro.
Try this also -> https://support.formuler.tv/kb/article/179…irmware-1-4-80/
No, I can not get to the main menu. When I turn the Z8 Pro on, I see a logo (I think) flash and then there is a low resolution text screen that states that I need to connect to an HDCP 2.2 HDMI jack. At that point, nothing works except the power off button. It is as if the Z8 Pro is defaulted to a 4K HDCP 2.2 resolution, does not detect a compliant HDMI on power up, and will not allow any further action.
Did you try the how to?
Connect the box with PC Monitor or other newer TV and change then the settings to hdcp 1.4.
Is your Z8 Pro connected to an A/V receiver and then connected to your TV?
If so, temporarily bypass the AVR and connect your Z8 Pro directly to your TV.
Thank you for your suggestions. I did both and the Z8 Pro is now working with my 1080p TV. Problem is solved.
