Hello everyone, I'm new to the forum and I'm not an expert on formulators. Can you tell me how I can deactivate the playback limit 3h on my Z8 Pro? I don't have an m3u line but a portal. Have also tried other portals but without success.
Playback Limit 3h Formuler Z8 Pro
Mytvonline2>menu>settings>playback limit>off
Be aware providers can also control this though and override it.
The 3h limit is greyedout and therefore I can't change that to off. I'm also on z8 pro and using stalker portal.
provider set if you can't change
Say to your provider that you want to use m3u line instead, after that turn your m3u line into xc api connection. This way your provider can't control it.
Extended Info:
Stalker Portal and Playback limit is always controlled by Provider. Between 3 and 10 Hours. 3hours are set as standard.
XC Api Portal and M3u are not controlled through Provider but you can set by your self the Playback limit or turn off.
Ok, nice. Thank you for the information!
