I watched the video but it wasn't clear how to record one channel and watch another. I am recording now and when I go to view a different channel, it says recording now and won't let me change.
Record on 1 channel and watch another or using PiP
- MYTVOnline2
Kennyh -
January 19, 2021 at 6:33 AM
The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.Is merge possible?
What is with PiP?
All above applies to PiP (Picture in Picture) too.
how I understood thanhhks
Thank you for explaining how different portal connections work and how MYTVOnline 2 features are affected.
Sam, could you explain this quote better? I am not catching on to this?
Is merge possible?
Means:
If you have two different subscriptions, you can not merge to use them as 2 connections. Only one subscription with 2 connections inside works.
Means:
Perfect, thanks
Would be very handy if the mytvonline2 app has a custom recording feature! For when you encounter a live event that the epg hasn’t updated. Etc a ppv show that doesn’t Have any information available? Which is often the case. I can record the show but have to wait up until 1/2/3 AM for the show to start to press record instead of setting a recording to a start & stop time. Just a suggestion for a future software update.
Just program scheduled recording on same channel at right time and let box start to record.
Can I just ask if you do not have two lines on the one connection you cannot change a channel while recording?
Nop , u can't. Just with pip
Still confused…. Do I need 2 paid providers to record one program while watching another ?
Thx
Your Provider account or called also as subscription have single connection. For watching and recording at same time ( with XC Api or M3u protocol) you need two active lines / connections activated from your Provider, thats all. Stalker/ MAC ID doesn`t allow more lines and use only one.
