Instead of playing the next episode, the VOD plays the first in the series. Does anyone know of a way to solve that?
Which model are you using? Mytvonline2 device automatically goes to the next episode at the end.
If you are using Mytvonline 1 device, you need to change the setting (default --> Play one repeat) to "Play All" by green button of the remote on screen.
He's posting in GTV section
I have No GTV to test on
Will try to reproduce today with my GTV.
Test with standard MOL2 VOD player.
Tested with Series and three episodes, the player ends seen episode and start with, for example 0101-> 0102 ->0103. Didn`t started the first or last seen episode at all, works all fine. Also the marker works fine and each seen episode is marked well.
Do you maybe use some external player for VOD and Series?
Hi Guys,
This is odd. Yes, it is GTV.
Pretty sure I am using the standard player but will confirm later tonight...Thanks
Ok, just checked and it is the standard player (I am assuming it is the standard player unless you choose some other external player). Also, just confirmed that at the end of episode 3 (for example) it says it is cueing up episode 4 but in fact plays episode 1. Funny thing is when episode 1 plays, the maker is transferred to episode 4. Pretty strange.
That's right. I tested on my GTV and it works fine in order.
That's pretty strange. Do All TV series have this problem or occurs in specific TV series?
No particular series - all act the same (regardless of the episode, upon completion it is the first episode that plays).
You may want to try uninstalling/re-installing mytvonline 2 and see if it was a temporary error. Otherewise I recommend you to create a ticket for Formuler technical support (https://support.formuler.tv/home/)
Your service provider is probably sending the episode index data in the wrong format.
Test with a different service provider and report back.
All good here aswell on a few different vod subs on standard player and all gtvs my end got be provider as mentioned above
I have contacted the provider and they will test on their setup. Thanks, I'll report back.
