  • I sometime have to unplug and re-plug my router to change my ip adress because the picture from iptv gets blurry and unstable.
    I wonder if setting a static ip would help this problem? I mean, if I find a ip that makes the picture stable, wouldn't it stay stable as it is the same ip all the time?
    I guess you could say no because it could be very nice one day and much worse the next day allthough the ip is the same. (that's my observation so far)
    Would really like your optinion on this and if it would help to do it?
  • Changing to static ip can sometimes help against buffering issues, but not with picture quality gets bad when a match is on, this is 100% provider side bad stream. Try to set static ip and clear mol2 cache memory and to be sure check with a different app like tivimate or a different provider.
