I can't find an option for using PIP on my z8 pro. How do I do it?
PIP
- Z8 pro
longshot -
April 7, 2021 at 2:52 PM -
- In Live TV, press the Info button
- Press the PIP icon at the bottom right of the screen
- Now you can see PIP enabled on your TV
Does that mean " Picture In Picture "?
I did what you just suggested and it took me to the EPG
Picture In Picture (PiP) starts also with long press on "OK" button.
PiP is only possible with one sub and two active lines, on XC Api Portal + M3U Playlist. Mac/ID Stalker doesn`t have PiP.
Hi
I don't get that option. The last ones are record and jump interval
Could you please explain and develop? What means "sub" (subscription?), so, is the PIP function not possible on 2 different subscriptions, be it in m3u, XC, or Mac? If not, is it in the "pipeline"? If yes, how or where can I find the exact procedure or tutorial?
https://support.formuler.tv/kb/article/107…n-mytvonline-2/
this will answer about your question.
All answers can be found in this Guidance thread, easy to find , is pinned -> Record on 1 channel and watch another or using PiP
How ever i will post it here again, because PiP + watching one channel and recording other feature need 2 connections in same sub. (subscription).
The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.Is merge possible?
What is with PiP?
All above applies to PiP (Picture in Picture) too.
