My epg dissapered! Any suggestions?
EPG
longshot -
April 9, 2021 at 1:55 PM -
Which app have you tested and observed this epg working with?
mytvonline2
try to do factory reset and reinstall
Solved it!
Just uninstalled and reinstalled the mytvonline2 app
Solved it!
When you do that, do you lose all your groups/channels?
No, I didn't
We have the option 'backup' called
Sure, which I do. But since we're not supposed to reuse backups between versions, I was wondering if un/reinstalling MTVO2 to troubleshoot would also nuke the groups, after all, we don't get all these software updates because everything is perfect...
Another good reason to write a backup procedure into MTVO2 to backup groups/channels only that can be restored. PITA to recreate a dozen groups with a hundred channels, IMHO.
