Is Netflix still not working guys
Netflix GTV
- Apps
- GTV
Den123 -
June 6, 2021 at 10:07 AM -
Netflix in Fhd is working.
i`m using the app followed in the thread in post above. No problems with 1080p.
Works
Do others also keep getting a message "netflix is not supported on this device"
I do occasionally, I think mostly after a reboot. Not a huge deal sometimes when I open the app but I just click ok and all is good sometimes a little pop up.
Appears so unobtrusive
I keep getting the popup message "netflix is not supported on this device" it's a bit annoying.
I got it working.
Go to
upgrades.montrealandroidtv.com
Klik to repo/android/netflix
1 out of 3 will work. No. 2 worked for me. Of course not upgrading. I was able to login and everything worked. Except………… I don't see a Netflix app Mmmm, when I click on number 2 again I get the message 'is already installed and I am immediately in Netflix. I'd rather have an app
I found a solution, turn off notifications.
