is anyone else having issues with their B** and I** channels since update? It seems to loop a few times with a black screen and then come back to live and skip those minutes that it was looping. It has done this a dozen or so times since yesterday afternoon. My provider has had no issues reported so could it be the update?
B** and i** channels looping since update
- MYTVOnline2
- GTV
Funhouse -
June 29, 2021 at 2:33 PM -
If your provider doesn't have any issue reported, you can change some adjustment of GTV .
-Auto Switch for best resolution OFF
-Colour space to YCBCR420 this will enable colour depth settings - ON.
-HDR to SDR -ON
-SDR to HDR OFF.
Its some method to reduce stuttering or lagging . try it
Thanks I’ll try it
all my settings were on that already. And still looping on a black screen. Seems strange how it’s only been doing this since update
The new update doesn’t work I start with a black screen and when i restart it start working really slow
Before the update I had 4K picture kwaliteit and now it’s fhd so the stopt picture kwaliteit upgrade
I know lots of providers last few days been struggling with these channels even B** iplayer tonight was doing it
Please no mention of channel names, thank you for your understanding.
