I have Z7 & Z8 very happy.
I have them in same room now and both remotes operate both models.
I only want the Z7 remote to operate Z7 model & Z8 to operate Z8 model.
Any ideas?
When I turn one on the other one gets turned off and vice versa?
Many Thanks
Edward
Remote problem
You have only one possible solution, to test with IR Eye.
Place left and right your boxes, connect IR Eyes to both boxes and place the ir eye so far from each other as possible.
box - ir eye <------------------> Ir eye2. One box with and other without IR Eye is also possible but then should the place between them be far enough so the IR signal can not be seen from other box.
Display MoreHi,
Any ideas?
Many Thanks
EdwardBuy the Formuler BT1 remote and use it in Bluetooth mode with your Z8
OK, thanks I will check it out.
Have a good day, sorry for delay in replying.
Edward -
Thanks Sam, I will check out IR eyes but seems awfully convoluted to me.
Will try it and see.
Again, have a good day, thanks for the replies.
Edward -
Sure, is not the nicest way, just possible. Problem is, both boxes react with both RCU`s you have in use, even if you use BT1 for Z8 the Z8 would react with rcu from Z7.
