Good evening, here is my observation when I watch a tf1 channel for example, the fps is 50, if from there I watch tf1 in replay and if I come back to the live of this same channel the fps is 60 with jerks obviously.
Afr gtv
- MYTVOnline2
- GTV
Tintin59 -
July 27, 2021 at 8:22 AM -
yes yes indeed me too I have the impression that the fps is kidding on a certain frequency image.on the z8 the parameters mto its in 50fps on all the application whereas on gtv c 60fps I pence that the bug comes from the but to be confirmed
hope a fix with an update.
with my other box z8 no problem, for the moment I regret my Formuler Gtv purchase.
frankly I also regret some bug it often blocks
i suggest turning afr rate to off as i have done it and as a byproduct of this, the channel switching is much faster as well..don't think you can blame gtv for providing you more features than less..
yes of course I can deactivate the afr but that will not solve the problem I find the gtv super May since the update of June I have this problem of afr bug and slowing down. but I do not want to deactivate the afr otherwise I have jerks if I go to 24fps or 60.
disable afr not the solution. a box of this price must have an Afr.
Why don`t you set and use only 50HZ, this is proper HZ for EU.
if we but on 50htz we have to remove the afr
here are my settings.
They are correct
Will try to reproduce this.
hello, following my problem Afr 50fps in replay and live return at 60fps, it does not do it in MAC connection. it does it in XC connection.
The developers are aware of the slow-down issue. Please try the next software update to see if it fixes your problem.
when will the next update be?
Maybe this week
ok thank you I hope that will solve the problem.
good evening, the gtv is completely crazy. when I turn it on it always comes back to the same channel, and sometimes the following error message. quickly an update.
hello should we reinitialize the box after the small beta update because it does not solve my problem of lag?
Please make a video of the issue using your smartphone and upload the video to https://streamable.com
Please make sure to show your fingers pressing the remote buttons and the lag on the tv screen in the video.
After that, use the chatbot at https://support.formuler.tv to create a support ticket and someone will help you report the issue to the developers.
If you have difficulty, PM me (conversation) here on the forums.
ok no worries i will do that it happens on my lg oled tv when i switch to a vod or a channel which broadcasts 24fps or some time on 60fps on the 50 is no problem.
I installed the beta, my problem 50fps in replay and 60fps in live, is still problem. really disappointed with this gtv. i have to buy for a friend, i don't think i will take FORMULER
No one is forcing you to use it. If you think the product is so bad, just sell it.
SAM, what's next to this problem.
Next is Now: I was trying to reproduce your issue and was only able (in 1hour testing) to see once 60fps after quit from catch up to live stream and with fluid Video/Audio! 1x shown/7x not. No jerks or other mismatches at all. Used same channel like in your video (FHD) and i guess also same known provider. This all of course with XC Api.
Interesting is, after i changed the resolution to 4k/60hz, afr shows each stream (live and replay) with 50fps, tried 5-6 times, always 50fps.
Don`t see here any bug. If you need some video proof from me i can make video and upload but not today.
thank you for your reply. I will switch to Mac connection, while waiting for a next update. or a factory reset for me. But I will lose my favorites. for when a favorite save function on Gtv?
